| been putting in o rings out of a national o ring set. talked to the local parts man today and he said they are not listed as a special oring. He thought the ones I was using may be too thick cutting them when I tighten them down. I put in a thinner ring on a couple and I think it is getting better. I am running it on a 8400 with the flow set wide open. Technicion I talked with said that should be fine. To answer your question John, Third year on the planter and blew maybe one or two last year but nothing like the 8 to 10 a day now. TIA | |
