| Man I've only used the stuff from gemplers once and am really disappointed with it. This was on a very rusty bin and the rust spots are showing through after a year and half. I did use a wire wheel on the 7" grinder to get all the loose stuff off. Gave it a coat of the gempler stuff let it cure and gave it another coat to make sure everything was converted. Then put a coat of white enamel over the top--now the rust spots. What do you do now?? Lot of work for the poor results. must be an easier way!!!! | |
