Posted 5/10/2009 21:39 (#709449 - in reply to #709345) Subject: Re: Air leveling valve line hook-up?
Central Illinois
Switch your supply line and your line to the bag then it will work, If you have them switched it will air up like it should just backward air flow but when it exhausts air it goes from your tank instead of the bags. also they will not act as soon as you move the arm, they are delayed
