Posted 5/10/2009 11:42 (#708892 - in reply to #708851) Subject: Re: Hiniker heat exchanger tube?
probably not, i haveseen this happen before the rate control valve stuck over the winter and burnt up the motor, i replaced the valve it worked fine after that but check and see if you show speed.
