| To Set SV1 and SV2 speeds use the dial to select the speeds you want. Then set the A and B Engine Speeds. In the headlands sequence select where you want the SV1 and enter it. To add the Engine speed you want A/B enter it where you want it to start. For Example: SV1 is 3.2 for turning around, SV2 is 5.4 for working speed. Engine speed A is 1500 for turn around and Engine Speed by is 1900 for working. In the headlands to start the field work enter B Engine Speed Symbol then SV2 Symbol (Engine will speed up then take of to correct mph setting). Do the same for Turn around enter Engine speed B Symbol then SV1 Symbol (This will reduce engine RPMS first then slow tractor down). IF you don't like where you put the symbols in order you can can move them around easily by editing the headlands menu.
