Boone, Iowa | Can you see if the pump coupler is OK? I cannot remember how Kinze drives the hyd pump. Maybe the splines inside the coupler have worn out and pump shaft is not turning. Probably a good bet that if you put a gauge in a hyd outlet, you are not getting any pressure, but you can check. If hyd pump is turning, you could pull filter and see if it is plugged. There is also the screen in the tranny housing you can check, if filters are plugged. | |
