| Until this year we used a EZ Trail 300 w 16' auger & telescoping spout. Son could fill our 16/32 Kinze 3600 without moving the wagon. We picked our hyds up from the control unit at the back of the planter. Had to buy a couple solinoids from Kinze that they use for the fertilizer fill auger if you had that option. Added a hyd coupler that hooks & unhooks under pressure on one of the row units at the back of the planter. Switch on the controller in the cab allows you to use the same hyds as the markers. | |
