Posted 4/28/2009 09:28 (#695607 - in reply to #694641) Subject: Re: 1990 ccs settings for beans
Kansas City area
More pressure won't necessarily help. You need to make sure the tube that the openers connect to is square to the ground, so the depth will be right. If you go to far you will wear your sed boots out early and won't get depth.
