| Was wodering if any body out there is running a micro trak pro plant with a third party controller. I am just getting mine hooked up and have some issues with the "multi plexer". Was wondering if the 3 little led lights on the underside of the muti plexer are supposed to be lit up--- at all times when power is supplied or just when the selinoids or open or what. (The multiplexer is used to run the pro plant when using a third party controller is used--- top con x20--). don't know if I have a problem with the run hold switch or what. Can't seem to talk to the right guy to day at micro trak--He is gone for the day. Any info would be greatly appreciated.
Thanks | |
