Posted 4/26/2009 15:30 (#693546) Subject: Monitor problem
Iowa
I have a 12 row 6100 White planter with a SM 3000 monitor. Row # 2 does not display. Switched sensor leads with # 1 and row 2 still does not display, so sensor is not the problem. Took monitor to White service department and they tested it and it worked fine. Problem must be in the wiring. Double checked and cleaned all connections. No help. What is my next step? Thanks!
