Search Forums | Classifieds (82) | Skins | Language
Kinze KM II monitor issue
RCT
Posted 4/26/2009 11:55 (#693345)
Subject: Kinze KM II monitor issue
S.C. Minn
Got a KM II monitor on my 16 row 30" 3600 planter. All spring it was been working great. The other day I decided I probably better clean out the seed tubes with a brush since I had planted about 850 acres and not cleaned them this year. So I shut the monitor off and then brushed each seed tube out with the Kinze brush they provided with the planter. Turned the monitor back on and now 7 of the rows are flashing telling me to "clean sensors". Not once did the monitor tell me to clean the sensors all spring. So I backed the planter over to the well, shut the monitor off and shot a little water in each tube, let it soak for a few seconds then took my brush and cleaned each tube again with the brush, went back with the water and rinsed each tube out again. Waited an hour or so, turned my monitor back on and now even more rows are flashing "clean sensors". I said forget it and went back to planting.
Any ideas what to do next ????
Thanks !!
