| I just got my new Case 12/23 split row planter with bulk fill. It has a 36 gpm pto pump. Does anybody know if there is supposed to be a relief or bypass in the system? If I don't turn my bulk fill and vacuum on from the monitor before I start the pump it will spike the pressure. I had a 5000psi gauge on the pressure side of the pump and it wrecked the gauge when I turned the pump on without turning the bulk fill and vacuum on. | |
