Springhill,Kentucky |
Anyone with a 230 Spra Coupe ever had problems with getting the transmission into reverse??This happened suddenly day before yesterday,no telltale signs leading up to it...I tried all the shifter adjustments from the operators manual,made no difference whatsoever...I know the volkswagons were notorious for problems there,am i more than likely looking at a transmission problem,or has someone else experienced this and found a simple solution?? Thanks.. | |
