EC IL | Was wondering if anyone has a setting with the CIH meters for using Force to start with. The planter has mechanical drive and the book says that the insecticde rate will change as the population rate is changed. The rate transmission runs the seed meters and the insecticide rate will change as per population. I had the boxes calibrated but then realized that the rate may not be right to start with and then if I change populations will change again. I only have four boxes on and the rate start was 2.2 on settings for the 4.4 per lbs rate and 6.5 mph. | |
