North Central Kansas | I pulled the wire out of the plug on my flatbed trailer the other day. Can't seem to get the lights to work right. I hooked the plug back like it should be according to the wiring diagram. Brakes work, taillights work, No left turn signal and when you put the right turn signal on all the lights blink. I checked the plug on the truck. The Right turn signal works but the left does not. Everything worked before I pulled the wires out. My turn signals work on the truck. Is there a fuse in the control box under the hood? I traced the wires on the trailer and they are wired correct. The wires on the truck all look to be good. 2004 Chevy 2500 with a 2008 EZ Haul trailer. | |
