| I am having a problem with my tractor keeping my planter lifted and I was wondering if any of you may have some advice. I am running a Case IH MX200 and a 2300 Kinze planter. I have pulled it with another tractor for years and, aside from leaky lift cylinders on the main frame, I have never had a problem with it leaking down. I thought it was probably the cylinders in the planter finally giving up but hooked it to another tractor and it stayed up. It raises and lowers just fine, just doesn't stay up over 30 or 45 seconds and it is on the ground again. I put the hoses in the other outlets and it didn't change it and also tried adjusting drop rate in the tractor and still no change. Any help would be greatly appreciated.Thank you. | |
