| Hyde, I think you should just try calibrating in the the field like the OM says. If you have a 100' tape to measure the 330', it should only take you a few minutes to do and then you will know for sure that it is as good as you can get it. I drove the 330' four times and averaged all 4 of them to do mine.
At first I tried manually fiddling with the number, but ended up doing the whole recal. Much better results for me.
Edited by sparrell 4/23/2009 08:45
