Central Iowa | The switches on the 6180 are all on the ground side of the system. If you have juice to all the appropriate coil for the function you are trying to do. (there is a chart located under the cover of the coils) More often than not you will have juice to the coil the problems usually result at the switches. The easiest thing to do for quick fixes is we have a ground wire attatched to the planter frame so that it is quick and easy to just start grounding probem coils. Many problems are also wires getting pinched can occur at the hitch pivot and lift arms on transport wheels.
