| When we put our gator in gear we step on the brake and shift. Then it will spit and sputter and when you step on the gas it dies. It seems to just be when it's cold. Once it runs and gets warmed up it's ok. Is this normal? It never use to do this. If you pull out the choke and step on the gas it usually won't die. It's a 2x4. I wanna say it's an 05, but not totally sure off the top of my head.
Thanks
Jake | |
