| My memory my be mistaken but I think when I got my last Kinze planter with that monitor it was doing the same thing. If I remember right you have to go through an inital setup of the monitor. I remember that you had to go through and plug in each shaft sensor and seed sensor in a certian order according to the manual to setup the planter monitor before the top screen will show anything. I am pretty sure it is in the manual on how to set the montior up.
Good Luck'
