Rosemary AB, Canada | Was out yesterday doing some light tillage work with the White, was running in 4th gear got back to the yard shut it off and went out today and it wouldn't shift into 1,2,3,4 but shifts into 5,6,R1,R2. I tried with the powershift in U,D,O but didn't seem to matter. When I try to shift into those four gears the shifter won't go into the slot even with a lot of pressure and I can't hear gears grinding. The linkages are tight under the cab. Any advice is appreciated. TIA, Ben | |
