Ayr Queensland Australia 4807 | to see a primary and secondary sensor out i would be checking the speed sensor on the timing cover pull the plug out and if oil is in it relace it. I had an 8100 last year that would run bad from time to time for no reason , on the tractors and i would say the 9600 will be similar the 5v power wire that supplies the power to the three sensors was bad at where it branches out in the harness.while i can not recall the code i would be checking this and all other wiring around the pump take the time to take the old condute off and check the wire condition and put new condute on ,if you have to pull the pump off get a tech to do it of coarse get one that know the engine. |
