Central Iowa | Im trying to get the front hub apart so I can replace the inner smaller seal. On the other ones that I have done the sun gear has pulled right out then you can take the bolts out to take the rest of it apart on this one the sun gear wont come out and I looked in between the axle and the hub and there looks like a snap ring holds it, in between the ujoints is this right and how do you get the snap ring off I can see it but cant find anyway to get to it to get it apart. TIA | |
