Search Forums | Classifieds (45) | Skins | Language
Cat 55 Power Beyond help
Smiley
Posted 4/12/2009 20:19 (#678126)
Subject: Cat 55 Power Beyond help
Decatur County, IN
Recently had a Power Beyond installed so we could have enough hyd outlets to run needed items on 1770 CCS. Normally we would not need extra but have Hyd pump for fert and Rawson hyd drive. Cat installed unit and it looks fine but the lower outlet (for return I think) is only for very small style tip not normal size (3/8"). Can anyone explain if we can/should switch to normal size? Also is this a low pressure return. The Cat dealer has not been able to answer our questions. We plan on running the two fans for esets on CCS from this connection. Also what order is the best to hook up the various conncetions in the stack for best use of oil flow.
1) Lift and fan
2) Markers
3) Rawson Hyd drive
4) Hyd pump for fert
5) Power beyond for fans
What is best order?????
Thanks in advance
