Posted 4/11/2009 20:33 (#677175 - in reply to #677133) Subject: RE: 7820 codes
It means you may be visiting the dealer very soon.
The code description is "sensor supply voltage low". - Maybe/probably from a wire touching ground. It's a long shot, but look around the oil pressure sensor at the RH rear of the engine.
