SE MN | Our JD 8410T got hot all of a sudden today. Earlier in the day I could hear the fan kicking into high and back into low. It does look like there has been a little weeping out of the hole on the water pump. Let it cool down some and the temp goes up fast after you start it up. The fan was running so it should not get hot that fast when it is just running and not being worked. Could the water pump be out? Themostats stuck? | |
