Posted 4/11/2009 16:55 (#677044 - in reply to #676838) Subject: RE: Strut Pivot Bearings Patriot XL 1994
As I recall it was pretty straight forward. Nothing complicated but takes a while to get everything off to get to it. I just tightened the nut till it got tight then backed it off to the nearest hole. Main thing is to get the play out and put a little preload on the bearing.
