Dublin, VA | I am building a 11 row planter for beans and need some help with the monitor. I have a 8 row harness that came with the donor planter and would like to add 3 more rows and change the flat connector to a 37 pin round. I will be using a computer track 150 monitor with standard sensors. There are 3 wires on each row, red (power I assume), black (ground) and green (sensor). I need to know that pin is what on the monitor? The monitor plug has wires in the 1st 12 positions, I am guessing these are the ones for the row sensors. There are 2 more pins farther down in the plug, which one of these is the the power and ground to branch to each row? Thanks
Scott
Edited by Rolling Hills 4/8/2009 12:46
