Somerville, Indiana | similar sized machines sometimes use buckets in that size range. 320 Cat uses 80mm pins I think, about 3.14 in diameter. You will need to measure your pins, distance between centers, and distance between the bucket bosses. You can also buy or make your own adapters, much cheaper than buying a new bucket.
www.adamsequipment.com has a list of used buckets with their pin diameters listed with them. Let me know if the link doesn't work.
Edited by dave morgan 4/8/2009 13:09
