Classifieds (34)
applying 32%, knife or inject?
Machinery Talk
oferiniowa
4/9/2009 08:49 (#674442 - in reply to #673450)
Re: applying 32%, knife or inject?
You shouldn't need a piston pump for 32%. You should only need 40 PSI and with a good flow meter and controller you can keep the rate.
I've always used an injector not a knife. Not sure why. It was what came on the first unit I had and I stayed with it.
IaAngus
: 4/8/2009 10:56
bad example
: 4/8/2009 11:49
IaAngus
: 4/8/2009 12:01
RE: applying 32%, knife or inject?
myron
: 4/8/2009 12:51
BHTN
: 4/8/2009 14:19
Jmark71
: 4/8/2009 14:21
Hickory
: 4/8/2009 18:24
steveMIfarmer
: 4/8/2009 19:20
Charlie SEMN
: 4/8/2009 22:33
oferiniowa
: 4/9/2009 08:49
