| did a in frame overhaul on a 94 series. last night idling around yard it developed a sqeak under the valve cover # 1 head. put a little oil on the ajusting screw it went away.
I though may be something could be between the push rod and cam lifter blocking a oil passage through the push rod. oil was cumming out of the rocker arm holes so I know that was getting oil may be it had not worked that far over. | |
