nw pa | recently posted on motor trouble with the old girl. Some oil in the water and water in the oil. Checked the oil cooler etc.. Had to run the combine as had no other options. Every morning drain the water out of the oil plus a quart and add a quart of oil. Same with the water. Put in some bar's leak and slowly the leak stopped. no water in the oil, still some oil film on the water but this could have been in the system. I think it is a cracked head and now that we finished will get into it. Have to give it credit though. Limped through 300 acres the way it was and still runs good.
Sometimes things go the way you like. | |
