Lee Co | I had 2 on one sprayer for a number of years (ravens) hooked to a 750 monitor. Now I have a sidekick w/ an envisio pro. all can bus. this was essentially a plug and play system. If you purchase from a dealer that knows what system you are going to use it with, they should be able to order all the necesssary components at one time, instructions are straight forward, biggest thing is draw out the way you want to plumb it in advance to work out the fittings needed. I would tee in to your rinse tank for priming, and rinseing out, drain etc. I used my 90 gal. rinse tank for product and added an additional 60 gal. tank for rinse. I don't like to spray anymone with out the injection system. you can change tates on the go, reduce water to finish a field, what ever you need to do. | |
