Posted 11/10/2006 08:04 (#59902 - in reply to #59217) Subject: RE: outback S to S2
The S2 is a good unit and will only get you the 50% increase if you pair it up with there EDrive steering system on you tractor. IF you are just using it as a light bar you are only going to see about a 25% increase that is do to the humane error factor.
