South Carolina | I am in the process of rebuilding my sprayer. The tank is mounted on the front of the tractor and a 1 1/2" hose is run to the inlet on a pto centrifugal pump. The pump outlet goes to a tee with a 3/4" throttling valve on one side, which then goes back to the tank for agitation. On the other side of the tee, it goes to a 3/4 electric pressure regulating valve and then into a 3 manifold boom valve setup which controls the left, center, and right boom. My question is what kind of valve would you put in front of the regulating valve to control the flow of liquid? Throttling valve? Ball valve? The boom is 45 foot 20 inch nozzle spacing with 3/4' lines. Thanks | |
