| My 7110 3 point hitch leaks down when the tractor is shut off. It makes working on impliments impossible with out being blocked up. I know they should be blocked up anyways if i'm under them but it still puts all the stress on the blocks. I have a rollover plow hooked in it now and while it stays up while it is running the pump is constantly laboring. I can see it go down a inch the jerk back up constantly. There is no external leaks so it has to be internal. My question is if anyone experinced this before or has any ideas on what it would take to fix. thanks | |
