| Thanks to all for the help. It did have the plastic impeller and new one was steel. The design of the water pump/block on these tractors is sad from my standpoint because if the o-rings fail and weep hole is plugged it could ruin the engine. Mine was leaking oil from the weep so I was half way there. Gonna bite the bullet and replace everything it could be that was mentioned here. Appreciate you guys. Eric | |
