West Central Iowa | Hi Kel,
The Case-IH size (3/8") equivalent is 9846567 which has a USA list of $ .58 This is a sub for two older IH numbers, 265204R1 and 222-104. JD also has a 3/8" line sleeve that is part number R49671. The R49671 is mostly used on the turbo supply line on the 531 and 619 engines. The R67092 is shown used for oil, fuel and coolant. JD parts show the ID and OD of the R49671 and the R67092 to be the same, but the material to be different. The R49671 is made of H2 (whatever that is) and the R67092 to be made of Viton. I do not know what material the 9846567 is made of.
The Case-IH part number for the R51936 (1/4") line sleeve is 222-101. The USA list for the JD R51936 is $1.30 and the Case-IH 222-101 lists for $1.14.
