| Mine's a MicroTrak SprayMate II and I'm usually spraying 6 gpa at 2-4mph over 100ft swath with a mistblower. I forget offhand what it usually says for gpm, but I'm thinking in the 3.5-7gpm range depending on groundspeed. IIRC, there's something in my manual about setting valve response speed but I don't have it here at the moment. The Microtrak customer service folks have been helpful when I ask questions, so if you give them some info on your setup they might be able to improve the responsiveness for you. I'm sure that'd help even if you went with a cruise control as well.
