"edge on" shanks purpose?
School Of Hard Knock
Posted 11/2/2006 00:20 (#57319 - in reply to #57285)
Subject: Great photo!
just a tish NE of central ND
A picture is worth a thousand words!Thanks for posting a picture!! It pretty much tells the whole story! My next question....... Is that opener in the picture made exclusevely by a EDGE ON companyor Concord, or do Dutch, Anderson and Stealth all make an opener that fits the application? I am thinking they look to be a quick change setup by driving out a roll pin to replace the parts?Is this correct?
Are the shanks O-E- M-optional or are they a changeover?
I also noticed your closers. Are those a single disc closer? They look somehow different and seem to have a different angle than those double disc units on concords around here.We usually see double disc closers used on sweep opener setups here(on older used machines) and some only have them on the back rank.Im not sure if they are used with paired row openers or not for certain.Seems to me I remember that the newer units have smaller discs.
Thanks again for the photo!
