NE Iowa | Got a 1997 854 RoGator and the oil temp will get hot when you run it down the road around 10 miles. I'm in a hilly area, so the road time is far from a flat drive. In the field, the temp is fine. Hydro charge pressure always runs around 500 PSI or so while having the throttle wide open and not moving. Haven't tried a new oil temp gauge or putting a temp gun to it to see if the oil actually is hot. Had hydro work done on it last spring and had wheel motors gone through as filings got sent through the sytstem. Cleaned hydro oil cooler out w/power washer and that didn't seem to so anything. Any suggestions? | |
