SE IL | Today I was checking over 16-31 planter. A neighbor with same planter had the support webbing that holds the wing locking cylinders crack and break. I have not seen his but found that ours was cracked, not completely broken yet! Can be fixed with out alot of trouble. If it breaks going down the road it would be a disaster. The back of planter in transport would more than likely be drug down the road. Has anyone else had this occur? The cracks on ours is on the 3x3 box support near the center mask. | |
