Search Forums | Classifieds (23) | Skins | Language
What is a Direct Drive semi transmission?
Badger
Posted 3/4/2009 20:35 (#631867 - in reply to #631821)
Subject: Re: What is a Direct Drive semi transmission?
Huntley Montana
Direct drive transmition is where the input shaft is running the same speed as the output in high gear. 2.90s are a little high for field work even with a real low hole in 1st. 3.23 is bad enough in the field
