Posted 3/2/2009 22:56 (#629604 - in reply to #629399) Subject: Re: JD 4700 hyd fluid?
NESD
The 4700's originally had hy-gard in the hydro/hydraulic system and had a lot of problems with hydraulic valves sticking, mid year 1999 there was a switch made to tjhe turf-gard which solved the sticking valve problems, I would recommend that you stay with the turf-gard.
