East cental Nebraska | We have a Rate controller set up on a 3800 24-30" . used the 4 tru-count clutches that came on the planter. Did not even have to change the harness to them. It will hook into the rate control with an adapter harness and works very well. Plan on at least 3 grand to do it. I believe you need a foot switch to power it up in the cab. also need the ISO harness out the back of the tractor. Plan on plenty of 12V sources. | |
