Southeastern, IL | Yea thats alot of dollars unless he has a money back gaurantee.(bet he dont) What about his elements will they fit a 70 series rotor. On our 9760 our dealer would change the rasp bars back to smooth like the 50 series had if you had a problem with breaking up cobs. They found them to help out on grinding combs because they was less agressive. I asked them about changing them on our 70 series but he said JD changed the bolt pattern. | |
