Posted 3/1/2009 21:22 (#628108 - in reply to #624126) Subject: Re: help with hyd tranny brake on versatile 555
Southeastern, IL
just a thougth but does people when driving the tractor push the clutch down all the way when the tractor is still rolling. If you do the clutch brake will be engaged and will wear out. If it is the same as our 875 was. Ours was a mechanical brake.
