Posted 2/24/2009 19:47 (#621434 - in reply to #621331) Subject: RE: Ford Genesis info needed.....
Mount Vernon, WA
Easiest way to tell is the large 1" diameter line coming in to the top of the remote stack. The standard pump flow comes in from a 1" line to the bottom of the remote stack.
The second pump is mounted directly below the first, to the rear of the gear case. You'd have to look behind the RH rear wheel to see it.
