Posted 2/24/2009 21:17 (#621567 - in reply to #620982) Subject: Re: Micro-Trak 3000 sprayer controller radar wiring
The trak star has a 6 pin connector on it and I believe a ground wire...?, that plugs into the 6 pin side. The 3 pin end plugs into the radar lead off of the main harness. If I remember that main harness had both a speed sensor/magnet lead and a radar lead, obviously you'd only use one. 'long time since I used one.
