That matters just as much as the size and length of the auger. Also is this a straight auger or does it have an angle joint in it? If it is a straight auger and you're talking ground feed or cracked corn/pellet mix or something of similar density it should do fine. If it has a joint in it and you are using it for premix or dical you'd need closer to a 1 hp if you wanted it to start by itself reliably.
